1941 Front Door Lock Cylinder Removal
Started by J. Russo, January 13, 2024, 11:59:40 AM
J. Russo
I have 2 front door locks with the same key code. I had new keys made. One lock works great. The other lock does not turn.
I have tried soaking with no luck yet.
Does anyone know how to remove the lock cylinder from this lock?
Photos attached.
John Russo
CLC Member #32828
DaveZ
Does the key go in? When you slide the dust cover over is there a pin hole in the face? Sorry it has been a few years since I looked at one of these:-(
Dave
David Zitzmann
1932 345B
J. Russo
I resolved the problem. There was a part inside sticking out from the side of the cylinder keeping the lock from turning.
Thank you
John Russo
CLC Member #32828
