59 suddenly stops charging?
Started by Cadillac Jack 82, February 22, 2024, 11:02:38 PM
Cadillac Jack 82
Everything is new on the car including wiring. While testing both the battery and gen they seem okay. Guess the Standard 35 amp voltage regulator just crapped the bed?  Made it home but those lights were dim. Thoughts?
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Every time my 62 stopped charging, it was the GEN
brushes, regulator was OK.  Easy to check.
Bruce Roe
Cadillac Jack 82
Does this mean I need to take apart the Gen?  I shot dust off in there and that didn't change anything.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Michael Petti
Test the generator and you will know. I think it should be 13.5 or 14 volts output if I remember correctly.
Jeff Rosansky CLC #28373
#4
Does the idiot light come on at all? How about when the key is on but engine isn't running?
1st thing would be to go ahead and flash it. If still no, then test the generator without the regulator. I think you ground the field wire, but Google that to be sure. If the generator is good it should run away with rpm. Then check the ground on the regulator.  Then clean the points in the regulator (battery disconnected of course).
There may be other troubleshooting tips in the manual.
Good luck
Jeff R
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Quick check on the gen is to momentarily  ground the field terminal on the gen., it would go to full output say 14-15volts., this eliminates the regulator.
Cadillac Jack 82
Well after further testing its the Gen. Shame because it's been fully rebuilt and restored. My question is what would cause it to suddenly crap out?  I ordered from a different vendor this time and hopefully this time no more boo boos.  I'd like to enjoy my 59 and not have a pretty lawn ornament...
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
dplotkin
Quote from: Dave Shepherd on February 23, 2024, 11:28:29 AMQuick check on the gen is to momentarily  ground the field terminal on the gen., it would go to full output say 14-15volts., this eliminates the regulator.
Except that on an AC car with a double contact regulator will burn up the contacts. Disconnect F wire from gen and ground F post as above.
Dan
60 Buick Electra six window
60 Chrysler 300 F Coupe
62 Pontiac Bonneville Vista
63 Chevy Impala convertable
63 Ford Galaxie XL fastback
65 Corvette convertable 396
68 Chrysler New Yorker
Never had to do that, musta got lucky. Lol
If the 2 wires to the generator were disconnected, an ohm
meter should read near zero from the main output terminal
to the case ground (through the brushes and armature).  If
it reads open circuit, brushes are gone.  Bruce Roe
