Rear wheel bearings
Started by Trouble, March 20, 2024, 03:18:27 PM
Trouble
Hi to everyone, (Newbie) first excuse me for any mistakes i am not to good on the lap top,i am having problems trying to find out the correct way to place Wheel bearings on my 1966 cadillac fleetwood 75 sedan, O ring out or in ? i removed RHS axle and the bearing on the axle has O ring on the outside,it has a metal shield on the bearing facing in to diff and a normal type seal facing out towards wheel,my new bearings have seals only on both sides,my question is what way does the O ring need to face? i have read  some old post here that talk about 60/61 bearings, facing out,any help will be great thank you in advance, Trouble
dn010
O-ring grove towards the splined end of the shaft. The idea is to have the o-ring sit deeper in the axle housing once it is put back together.
-----Dan B.
'81 DMC DeLorean
Trouble
Thank you for the reply, mine are on the axle O ring out,the bearings have a metal cover on the O ring side and a rubber seal on the other side? the new bearings are rubber seals both sides,i think i will put the new ones on as you said O ring in cheers
dn010
#3
Install it as illustrated below. You can't really go by comparing the new and old bearings side by side, these bearings were updated and improved over the years for better sealing. As long as it is installed with the o-ring groove facing the splines as indicated, you'll be fine.
-----Dan B.
'81 DMC DeLorean
Trouble
wheel bearing back on axle to correct measurment, O ring facing inside car driving great, thank's to all,big thank's to Bruce
