Oil Dipstick Tube
Started by 49 Caddy, March 22, 2024, 12:23:06 PM
49 Caddy
  Bought a 49 Cadillac with a seized motor that I am in the process of rebuilding.  Came without an oil dipstick and tube.  I found a used tube and dipstick, but am at a loss.  Hole in the pan is threaded and the tube I have is smooth.  Does it just press in or has someone sold me the wrong tube?  Looks the same as others I have seen.  The hole in the pan had a plastic threaded plug installed in it.
Jay Friedman
You have an "early" 1949 motor which has an early oil pan.  The dipstick and tube you found are for a "late" '49 as well as '50-'53 motors.
Look at the VIN number which is stamped on a boss just in front of the number 2 cylinder (front cylinder on right hand or passenger side bank). The first 2 digits should be 49; the next 2 digits should be 60, 61, 62, 75 or 86 signifying the Series of the car. The last five digits of that number are the engine number. In 1949, until engine number 61621 the oil pan and dipstick assembly were "early".
On the early oil pan the dipstick is inserted into a threaded pipe which screws into the hole in the oil pan you mentioned. You will have to buy a pipe or you could have one made by a machine shop as it is not complicated.  If you decide to have it made, get back in touch with me and I'll send you the dimensions. If you try to buy it, besides ebay you could try Cadillac parts dealers Dennis Akerman or John Gately whose addresses are in the New Hampshire and Massachusetts sections of the CLC directory, respectively.  Another source would be Arizona Vintage Parts or Desert Valley Parts in Arizona.  At the same time, of course, you will have to buy an early dipstick.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
J. Russo
I don't know what yours looks like but there are several 1949 Cadillac oil dipstick tubes advertised on eBay.
John Russo
CLC Member #32828
Jay Friedman
Quote from: J. Russo on March 22, 2024, 07:52:47 PMI don't know what yours looks like but there are several 1949 Cadillac oil dipstick tubes advertised on eBay.
I just had a look on ebay and all those I saw were "late" 49 (and 50-53) dipsticks.  49Caddy needs an early dipstick.
Decatur, Georgia
49 Caddy
  Dimensions for that dipstick tube would be appreciated, Jay.
Jay Friedman
#5
Glenn,
Dipstick pipe: length = 14½ inches; Outer diameter = 17/32 inches; Inner diameter = 3/8 inches.  Lowest 3/4 inch or so has pipe thread to screw into oil pan.
Dipstick total length = 18¼ inches;
"Add Oil" point is 1 7/16 inches from lower end;
"Full" point is 2 5/16 inches from lower end.
Decatur, Georgia
49 Caddy
Jay Friedman
Quote from: Jay Friedman on March 24, 2024, 11:18:40 PMDipstick total length = 18¼ inches;
Glenn,
I forgot to mention the dipstick total length is calculated from the stop under the handle.
Decatur, Georgia
