1949 Series 62 Fuel Delivery Issue
Started by bobchaney, April 06, 2024, 04:31:09 PM
bobchaney
I have both an Airtex and mechanical pump along with an inline filter that has a clear sight glass. She quit on me coming home the other day and had to have my son in law pull me home with his Jeep. It acted like it was out of gas even though I know the tank is full. I just took a look and the nothing in the sight glass and I can hear the Airtex trying to pump but nothing. Looks like I need to drop the tank and of course it's full. I assume siphoning isn't difficult but what do I do with 20 gallons of fuel that is probably old and shouldn't be used?
1949 Cadillac 6269X
CLC# 28432
Cadillac Jack 82
Lines might be clogged.  You can either try to remove and clean them but it might be best to get new lines since its the fuel system.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
V63
If the fuel is 'old' it's best not to run it thru your engine. It can result in seized valves.
Be sure to verify the suction side of the fuel supply is sound, the slightest compromise will inhibit flow.
The 1949 does have a factory drain bolt on its fuel tank.
Bob Kielar
Perhaps you could try to take your gas cap off disconnect the line at the engine and blow very low pressure air into the line and see if you hear bubbling in the tank. The reason I say low pressure there might be a sock filter in the tank and you wouldn't what to blow it apart. Or you could disconnect the line at the tank and blow air from the engine line.
Keep Cruzin,
Bob Kielar
Keep Cruzin
1955 Cadillac Fleetwood
Jeff Rosansky CLC #28373
Did you happen to take the gas cap off when she quit on you? I would try starting it now, after its been sitting, to see if you have any fuel. It's possible your vent could have been plugged.
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
