1960 Plug Wires
Started by 60eldo, April 18, 2024, 06:44:13 PM
60eldo
 Im confused on which spark plug wires to buy. Some say carbon core, others say suppression. Which is the best wire for my 390  1960.
Jon. Kluczynski
Solid core wires are incompatible  with any electronic ignition if you have any plans. Also tend generate static especially in oe radios. Carbon core wires a little more fragile, but are a common choice.
Leads marked either Carbon Core or Suppression are the same.
The other types are Spiral Wound and Solid Core as was in the olden days.
The Spiral Wound leads are mainly used for Performance, where there is no radio in the vehicle.
If you do use the solid core leads, and have a radio, you need to put Suppressors on each item that can suffer from electrical interference.
60eldo
My radio is an after market. And Im on points and condenser.
Jon. Kluczynski
Jon S
Original wires were Packard TVRS.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
Lexi
Lectric Ltd (Chicago?) has reproduction wire sets for our cars. Made just like the old days, even using some old equipment. Fusick carries them, (or last I checked they did). Clay/Lexi
If you are not going for 'correct' looking wires I have had good luck with the Belden wires. They are also usually dark blue so look pretty decent with the Cadillac blues.
