1956 dealer installed AC system
Started by jwwseville60, May 08, 2024, 08:50:47 AM
Some of those early factory units used almost
the same equipment as the add ons.  I used a
couple of them with good results for many years.
The important thing was to adequately upgrade
the cooling system, basically to late 70s
standards.  Bigger radiator, overflow tank,
fan, and a fan shroud.  Bruce Roe
RFCaddy1977
https://www.drukautosales.com/vehicles/207/1956-cadillac-eldorado-seville
This car appears to have a dealer installed AC system.  There is no "K' on the data plate.
Robert
J. Gomez
@Clay, @rick,
FYI
The one I had measured 22"x2" and it seat flush with the inner front support panel lip, the rubber strip is similar to the new masticated rubber material.
HTH
J. Gomez
CLC #23082
Jeff Rosansky CLC #28373
Didn't the actual Factory AC cars have bigger springs up front, and a different rear end to account for the extra weight and drag on the engine?
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
RFCaddy1977
Yes, when I replaced the front and rear springs on my 56 Seville, there were 2 choices - AC or no AC (mine has AC).   I assume the dealer would have upgraded these if a customer had AC installed.
Cadman-iac
Quote from: Jeff Rosansky CLC #28373 on May 14, 2024, 08:58:15 AMDidn't the actual Factory AC cars have bigger springs up front, and a different rear end to account for the extra weight and drag on the engine?
 I would think that it would have heavier springs in the rear, but I don't have any non-AC cars to compare to, other than the 55, and it's a different body style than my 56 coupe.
 I do know that there's an 1/8" shim on top of the right front coil spring because of the weight of the compressor and related hardware.
 Rick
CLC# 32373
Lexi
Quote from: J. Gomez on May 14, 2024, 08:50:50 AM@Clay, @rick,
FYI
HTH
Here is what was advertised by the vendor. Look them up and enquire as to whether they still offer this item. Clay/Lexi
Cadman-iac
Quote from: Lexi on May 14, 2024, 11:47:14 AMHere is what was advertised by the vendor. Look them up and enquire as to whether they still offer this item. Clay/Lexi
 From looking at this, I can make my own without any problem. Like all of these shields, baffles, and splash guards, the hardest part is putting the damned staples in.
 Thanks for the information though, I'll give them a look at least.
 Rick
CLC# 32373
