1959 Trailing Arm Bushings
Started by Cadillac Jack 82, May 22, 2024, 02:02:50 PM
Cadillac Jack 82
I just purchased a nice set of trailing arm bushings for my 59.  How difficult are they to install?  Mine seem fine as is however they're over 65 years old.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Gabe Davis
Where did you get them from?
My '59 has a nasty driveshaft vibration and I'm pretty sure it related to the pinion angle being out of spec caused by the bushings being old and collapsed. I think this job is in my future too.
1959 Coupe DeVille
Rosewood with Dover White Top
Cadillac Jack 82
Found em on ebay from someone in Canada.  Supposedly made by a well known guy.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Clewisiii
So you got some of the Dan McNarry bushings. Harder durometer then the original.
He has YouTube videos showing before and after with his set up.
Clewisiii
Here is his before video as he was trying to determine how much movement the rear differential was having with the old bushings.
Moody
Not too difficult if you have a press and the rest of the tools for the job. Plenty of YouTube videos show how it's done. Caddy Daddy does some for a '59.
Moody
Do I see a Ford 9" diff there?
There is a lot of movement there, plus some unpleasant knocking sounds.
Clewisiii
Quote from: The Tassie Devil(le) on May 24, 2024, 08:33:50 PMDo I see a Ford 9" diff there?
Yes that was his before. He made new bushings and custom trailing arms to stiffen it up. I saw an after video years ago. But I don't know if he took it down.
Clewisiii
Cadillac Jack 82
Thats him.  Set was for 75 bucks so I figured it was a good buy.  The ones in there...even after 65 years...are amazingly solid and soft.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Quote from: Gabe Davis on May 24, 2024, 03:34:06 PMWhere did you get them from?
Where the carrier bearing is mounted in the 'tunnel' of the frame, there are shims mounted under the bearing mount that control the forward shaft angle. Many times if the shaft has been removed, those shims are either left in the tunnel or eventually fall out while driving.
I ended up taping fender washers to the bearing mount so I could get the bolts back in without losing the shims. It takes time and patience to remove and replace the shaft enough times to get the vibration out. Mine was between 45 and 60 and if my feeble memory serves me right, I put in near 1/4" of washers to get the angle right. That meant an R&R procedure 3 times.
I loved my '59, but the gremlins it had kept me under it a lot.
Cadillac Jack 82
Quote from: Big Fins on May 25, 2024, 09:08:45 AMWhere the carrier bearing is mounted in the 'tunnel' of the frame, there are shims mounted under the bearing mount that control the forward shaft angle. Many times if the shaft has been removed, those shims are either left in the tunnel or eventually fall out while driving.
Hmm what did you run into?  I find the 59 to be very simple and reliable
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Quote from: Cadillac Jack 82 on May 25, 2024, 12:20:20 PMHmm what did you run into?
Hmmm! A GM Engineer? I didn't design the frame and drive train. I was only a year old when they were built. But, IF you were to bend the forward shaft, I'd say that you were in no place a Cadillac should be. ;)
Quote from: Cadillac Jack 82 on May 25, 2024, 12:20:20 PMI find the 59 to be very simple and reliable
On to the simplicity claim. We are still talking about a '59, correct?
It's a two piece shaft with a carrier bearing. No way to grease this bearing or the universal joint, due to it being inside a tunnel. (No worries. There were other years for this too.) Then there was the pressed in rubber bushing in the rear section of the rear shaft that had the rubber bushing in it facing the wrong way. It captured every piece of dirt on the road that blew up in that direction.
This caused the rubber bushing to be in a constant state of wet and dry, depending on the climate driven in. The use of said rubber bushing also caused it to be twisted out of phase when the rubber dried out too much and any use of those 325 horses were called upon.
Luv the '59's, but just saying! None of them are perfect. If they were, we'd have nothing to complain about!
Quote from: Big Fins on May 25, 2024, 04:56:37 PMOn to the simplicity claim. We are still talking about a '59, correct?
Don't forget that they were only designed to perform perfectly till the Warranty period ran out. ;)
They were never designed to last as long as they have, which is why they made spare parts for the. (It is the Spare Parts counter that is where the profits are).
Cadillac Jack 82
Well Fins idk what you ran into but on this side I find them to be quite simple.  Perhaps I lucked out and got one that was well taken care of?  The one thing I'm not looking forward to is replacing the rear ball joint.  Looks as if its riveted in.  The rear diff definitely shows wear cosmetically but then again she did come from Pittsburgh.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
This is the rear ball joint.
Cadillac Jack 82
Guess it needs to be drilled out?  Why would they make something so complicated?
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Quote from: Cadillac Jack 82 on May 25, 2024, 10:12:08 PMGuess it needs to be drilled out?  Why would they make something so complicated?
Because riveting the ball joint was a cheap method!
Clewisiii
And the warranty was either 30 or 90 days.
