1961 wiper arm removal
Started by MidModCad, May 29, 2024, 09:19:16 PM
MidModCad
Is there a way to remove wiper arms on a '61 coupe without using the special tool?  Saw a couple of youtubes where people leveraged with screwdrivers, but their cars weren't Caddys.  If not, is the tool the same commonly available one seen everywhere?  Thanks.
Cadillac Jack 82
Should be like any other GM of the era.  Pull out and rotate 180 degrees in the arm.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
quadfins
I used to use a screwdriver to pry the arms off, but then discovered this tool. NAPA, IIRC. Very helpful and no more fear of scratching paint or denting chrome. They act like pliers, except the jaws expand when you squeeze the handles.
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
DeCou Driving Award x 4
Clewisiii
I used a dental pick to pull the tab back and lift my arms off.
CadillacFanBob
Quote from: quadfins on May 31, 2024, 03:54:27 AMI used to use a screwdriver to pry the arms off, but then discovered this tool. NAPA, IIRC. Very helpful and no more fear of scratching paint or denting chrome. They act like pliers, except the jaws expand when you squeeze the handles.
Jim, is a part/tool number on your tool?
Bob
Frankfort, Illinois
quadfins
I will check when I get home
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
I'm confused about what part he is trying to remove. Is it the entire arm off of the mounting to the transmission at the cowl grating, or the swivel section that holds the blade refill itself?
MidModCad
Yes, took the entire arm off the shaft.  I used a combination of one medium and one large screwdriver and a thick layer tape to protect surfaces. I used the small screwdriver to slide the tab over, then leveraged the large screwdriver against the base with a small piece of wood.  Worked fine, but the right tool would surely be easier (as usual).
When you put them back on the splined transmission end, just dab a little Never-Seize on the splines. Then if you need to remove them again, just lift the arm off the glass, slide the retaining tab out and gently lift them off.
quadfins
not much of a serial number, but...
XD 2039     and "made in USA"
maybe if you take the picture to various auto parts stores, they would recognize it,
Jim
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
Clewisiii
Tassie. Here is that picture. Can you delete your link.
Clewisiii
Quote from: Clewisiii on June 01, 2024, 11:57:30 AMTassie. Here is that picture. Can you delete your link.
Done it.   I hate it when those eBay links won't simply stay within a reasonable area in a post.
