1960 Carter carb
Started by 60eldo, June 14, 2024, 07:57:28 PM
60eldo
Looking for a good working carter carb . Let me no if u have one, or non working preferably 3352S ,but any 60 carter will do
Jon. Kluczynski
Lexi
Think I may...may have an intake manifold should yours turn out to be cracked. Think mine is for a '59, and if so, would have to check my parts books to see if it would fit your '60. I am not that far from you so shipping would be at a savings. These parts are cast iron and heavy. Off chance I got one carb left, but almost certain it is for a '59 also, and a Rochester if memory serves. So probably struck out there. Clay/Lexi
60eldo
#2
 I have another intake, but i may be interested in your carb if it will fit my linkages, Is it a running one or does it need rebuild, tell me about it
Jon. Kluczynski
Lexi
If I still have it, it would require a rebuild. It may also have the idle speed up control on it. Clay/Lexi
Lexi
I have other rebuilt carbs but they are not suitable for your car. I can put you in touch with a carburetor rebuilder in Ontario if need be. Clay/Lexi
60eldo
Jon. Kluczynski
Lexi
Quote from: 60eldo on June 17, 2024, 08:24:04 AMWho do u recomend
Not many left, but Moffat Carburetion Specialties still rebuilds carburetors. Al can be still be seen attending the shows and has done 2 of my carbs. He is located in Jarvis Ontario, a hike for you, (perhaps 2.5 hours away?). Contact number is 519-657-9040. Think I have another one here somewhere if that one fails.  When you pick up your finished carb he first installs it on an engine mounted on a stand which he fires up. Don't recall seeing a bench flow tester, but seeing & hearing your rebuilt carb on an engine at pick up time is best. Clay/Lexi
60eldo
 He has closed down, I tryed him
Jon. Kluczynski
Clewisiii
You probably do not want to ship to far away. But my Rochester was rebuilt by Custom Rebuilt Carbs. They also test on an engine before shipping.
Lexi
Quote from: 60eldo on June 19, 2024, 08:36:06 AMHe has closed down, I tryed him
I just saw him at a show this April. If he has closed it must have been very recently. I will look for another number. Clay/Lexi
60eldo
Do you have a good core for me
Jon. Kluczynski
Lexi
Quote from: 60eldo on June 20, 2024, 09:17:20 PMDo you have a good core for me
I will look when I next get to my storage area, but probably don't have one. I did find another number for Moffat  Carburetors; 905-515-3495. Sure hope he is still rebuilding carbs. He was set up at a booth at a car show this April still advertising his rebuilding service. Had a chat with him. Clay/Lexi
