1960 dash covering
Started by Moody, August 22, 2024, 05:08:01 PM
Moody
I have some cracks in a dash that I'm trying to do a small repair on. I'm planning to just plastic weld the spot to stop it's spread if I can. Curious what the material actually is made of?
Moody
Clewisiii
Show a picture. I believe the top skin is a PVC vac formed compact sheet.
You can buy a vinyl/leather repair kit that works like a flexible filler.
Moody
The car is not here, this is a friend's car. I'm afraid it will just continue to crack to pieces like mine has. Good tip on a repair kit! That would be easier than plastic welding, which was my first thought.
Moody
59-in-pieces
David,
Just a thought, try to copy the pattern embossed in the covering on each side of the cracked repair area to hide the patch.
Otherwise, it may look like a smooth section between embossed patterned areas.
Have fun,
Steve B.
S. Butcher
