1970 DeVille 472 A/C Compressor delete question
Started by Bill Kaufman CLC# 15225, August 26, 2024, 01:12:57 PM
I am working on my 70 Deville Vert 472. Has anyone had any luck bypassing the A/C compressor by running the two power steering/ ac belts directly from the flywheel to the power steering pump ?? if so, what size belt did ya use.  Thanks,  Bill
If you ain't Wrenching ...  You ain't Livin.  So get out there and Live a little..  !!
Current Labors of LOVE;
1948 series 62 Club Coupe / 346 L head / Rendon Blue
1954 series 62 Sport Coupe / 331 V8 / Aztec Red
1970 Deville Rag Top / 472 V8 / Nottingham Green
Previous Caddies ;
1969 Fleetwood Eldorado / 472 V8 / Wisteria
1974 Sedan DeVille
1993 SLS / White Diamond
2006 CTS / White Diamond
That is how the factory did it for non ac cars and the manuals lists the belt size.
Also note that at least one of the rear compressor bracket mounting holes going into an intake runner so it needs a bolt installed to plug the hole.
Highwayman68
The manual lists one 48" belt is needed for non-AC cars.
Would like to have The Chattanooga Choo Choo
Previous Caddies ;
1974 Sedan DeVille
