1949 Cadillac series 62 double ferrule for hard fuel line to tank
Started by Po3824, September 11, 2024, 11:27:11 AM
Po3824
Can I get some advice on purchasing the double ferrule associated with the fittings between the hard fuel line to the gas tank.  There is little data our there as to specs related to this tiny part.  With out the double ferrule leakage will occur.
I decided to send my tank to tank renew who changed out my fitting to from a 5/16" to a 3/8" not requiring the spacer.  I found a near impossible situation staying with the old fitting.  Thanks for all of the advice.
Patrick O'Kelly
pokelly45email addresses not permitted
248-797-1383
Rossoroo
There is someone on this forum who is parting out a 47. Perhaps that would have one.
There is also the 48-49 Cadillac facebook site. There's lots of people who are modifying cars there. Perhaps someone is getting rid of the stock tank.
49-6269 My First Caddy
Joe Jensen
Patrick:
Here is an old link to someone that was selling those.  Maybe he still has some.
https://forums.cadillaclasalleclub.org/index.php?topic=166157.msg504066#msg504066
Some of the replacement tanks don't use these.  If you have an original tank then you must have one.
Good luck!
Joe
Jay Friedman
The orignal fuel tank on my '49 had a ferrule.  I bought a replacement for that tank from Kanter which did not need a ferrule since a female compression fitting was built into the place on the tank the male compression fitting on the fuel line attaches to.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
David King (kz78hy)
I have the part print for the spacer, but have not made any as there is very little demand for them, and it is harder to make than the 50-58 style spacer which I list on my website.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Po3824
Quote from: Rossoroo on September 12, 2024, 05:52:19 PMThere is someone on this forum who is parting out a 47. Perhaps that would have one.
Thanks Joe, I decided to send my tank to a restoration service and have the tank fitting changed out to a 3/8" not requiring the double ferrule spacer.  I appreciate your quick response.  Patrick
Patrick O'Kelly
248-797-1383
Po3824
Quote from: Joe Jensen on September 12, 2024, 10:57:56 PMPatrick:
Good luck!
Joe
Patrick O'Kelly
248-797-1383
Po3824
Quote from: Jay Friedman on September 13, 2024, 08:44:16 AMThe orignal fuel tank on my '49 had a ferrule.  I bought a replacement for that tank from Kanter which did not need a ferrule since a female compression fitting was built into the place on the tank the male compression fitting on the fuel line attaches to.
Thanks , I decided to send my tank to a restoration service and have the tank fitting changed out to a 3/8" not requiring the double ferrule spacer.  I appreciate your quick response.  Patrick
Patrick O'Kelly
248-797-1383
Po3824
Quote from: Po3824 on September 11, 2024, 11:27:11 AMCan I get some advice on purchasing the double ferrule associated with the fittings between the hard fuel line to the gas tank.  There is little data our there as to specs related to this tiny part.  With out the double ferrule leakage will occur.
Patrick O'Kelly
248-797-1383
David King (kz78hy)
For the next person to find this thread, I made a couple of the 48-49 fitting.  P/N is 1455530.  Spacer, Fuel Tank Outlet.  $35.
David King
CLC 22014  (life)
1955 Eldorado #277
2012 Volt
