1966 deville - Can regular high beam switch be used on guidomatic system?
Started by 66DevilleRagtop, September 18, 2024, 10:32:33 AM
66DevilleRagtop
Quote from: TJ Hopland on August 31, 2020, 10:56:28 PMThe extra wire on the dimmer switch is part of the Guide-Matic system which when engaged uses a sensor to sense oncoming lights and turn off the highbeams.
I need to replace my foot switch and the ones online (without the extra wire) are very cheap, but the direct replacements of the extra wire switch are much more expensive and used, etc...
I do not need the guidomatic system to work, will the (cheaper GM standard $10) brake switch work without the extra wire connected?
