1956 Hydramatic Trans Flush
Started by Dave CLC#16900, October 03, 2024, 01:12:09 AM
Dave CLC#16900
Hi, off to visit my long term project/barn find/ "Howard's Eldorado" / or as I like to call her, "Bernadette".  The previous owner bought the car in Chandler, AZ in 1970 from a film company that was shooting a Western in Tucson.  He had the transmission rebuilt in 1978 and said it was never right.  Howard parked her in 1981 when reverse stopped working.  He started some disassembly of trim to repaint the car and stopped.  I bought in 1990 from a local man that bought it to flip it from Howard.
I rebuilt the fuel and brake system immediately and drove it a couple hundred miles.  Seemed to work ok for me except reverse was not good when hot and made grinding noises.
I then took a long break from working on it.  Had to change storage locations 3 years ago and got it running again.  Reverse is not working now, may be low on fluid.
Going to lift the car up for the first time in 20+ years and drop the trans pan.  Was considering putting a quart of lacquer thinner in the fluid to loosen up the crud first, running it on the stands with minimal load. Then draining all the fluid possible from the fluid coupling and pan. Is adding thinner a bad idea?
I have a spare '56 Eldorado transmission but condition unknown from my parts car.  That car was parked in the 70s due to severe rust issues living in Pennsylvania.  One point of getting under the car is to see if Bernadette has her original trans or not.  Howard thought it was original.  If it isn't matching I may just send the parts car's trans for a rebuild.
Thoughts?  Would be great to make some short drives in the car next week....and replace the passenger window, and install the rebuilt antennae, and......
Dave
Dave CLC#16900
1956 C 6237SDX ELS
1975 C 6CD47 CDV
Jeff Rosansky CLC #28373
For what it's worth, we had this same debate when we woke our 55 up. A lot of people here chimed in.
I decided not to change the fluid and just run it. The shifts weren't great, but it shifted. The more I drove it, the better it got. I am happy I didn't change the fluid.
Now with that said, it leaks so it has had a poor man's fluid change over the last few years. But it still shifts ok.
If it is driveable, my advice would be to just drive it a few hundred miles and see if it cleans itself up and gets better.
You can always change it, but you can't unchange it.
Just my thoughts.
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Cadillac Jack 82
If the 56 is anything like my old 55, just top her off with fresh fluid and drive her.  Mine sat for a while and was clunky from 2nd to 3rd gear.  The more I drove her the better she got to the point where I never noticed shifting as much.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
If the '56 just has a screen for a filter and a drain plug in the pan, you have it made. I don't know, because I never did any work on a '56.
Why manufacturers can't put in a simple drain plug anymore is beyond me. My pick-up doesn't even have a transmission dipstick. You have to crawl under it, remove the fill plug and there is a little 1" stick on the end of the plug. Modern idiocy!
Lexi
#4
The '56 does have a screen inside the transmission and 2 drain plugs; 1) on the pan cover, and 2) one called the "torus drain plug". Shop Manual says to check after running, when refilled partially to start, in N or P for 1-1/2 minutes at 800 RPM, then slow idle, wipe dipstick, and check fluid level. The level should be within 1/4 of an inch on the "Full" mark on the transmission dipstick. Add as required by what the stick says and not rely on what volume of fluid you added. Yes, "modern idiocy" with respect to modern transmission fluid level checking. Clay/Lexi
Lexi
#5
Quote from: Jeff Rosansky CLC #28373 on October 03, 2024, 09:26:19 AMFor what it's worth, we had this same debate when we woke our 55 up. A lot of people here chimed in.
Just my thoughts.
Jeff that is exactly what I did. At first I had some rough shifts and even slippage. All gone after driving it for a few hundred miles, then all negative issues disappeared. Yes, a "poor man's" oil change is what Lexi got-but later a transmission shop did a complete change. Fortunately all went well and has remained so. Clay/Lexi
Quote from: Lexi on October 03, 2024, 02:53:36 PMThe '56 does have a screen inside the transmission and 2 drain plugs; 1) on the pan cover, and 2) one called the "torus drain plug". Shop Manual says to check after running, when refilled partially to start, in N or P for 1-1/2 minutes at 800 RPM, then slow idle, wipe dipstick, and check fluid level. The level should be within 1/4 of an inch on the "Full" mark on the transmission dipstick. Add as required by what the stick says and not rely on what volume of fluid you added. Yes, "modern idiocy" with respect to modern transmission fluid level checking. Clay/Lexi
I forgot about the torus drain plug. Between that and the pan plug, you can get most of the fluid out.
As far as a 'flush' goes with an additive, NO. It may totally ruin the internal seals and friction plates.
I always disconnect the pressure side of the cooler line, put it into a vessel large enough to hold a couple of gallons of fluid, then pour new fluid down the dipstick tube, run the engine at idle until the fluid runs clean. If you have a paper type filter, that doesn't fix that if it's blocked, but after a fluid swap, drop the pan, change the filter, pan gasket and top it off. It's about a $30 flush at the price of fluid these days.
Dave CLC#16900
I appreciate everyone's feedback.  I already have a pan gasket for the trans and really want to drop it and see what is in there.  Will drain the Torus cover too.  From what I learned in the shop manual the pressure is the highest in reverse.  I want to drop the pan to see what has collected there and make sure the pickup is clean.  Heard Walmart is the best place to buy Dex/Merc trans fluid.
Will skip the additives or lacquer thinner.  Would be awesome if this healed itself, but as the loss of reverse is why it was parked, am very doubtful.
Dave
Dave CLC#16900
1956 C 6237SDX ELS
1975 C 6CD47 CDV
Quote from: Dave CLC#16900 on October 05, 2024, 07:14:54 PMHeard Walmart is the best place to buy Dex/Merc trans fluid.
Dave
Funny you say that. I just finished my gallon jug that I've had for years and got another one yesterday.
Walmart had almost the best price but I found it at Menards a couple bucks cheaper.
Jeff Rose
CLC #28373
Dave CLC#16900
#9
Well I got back from my trip to visit Bernadette, my Seville.  Learned a few things, including how many bolt holes are in the trans pan.  It has leaked a fair amount of fluid since it was parked 3 years ago.
I knew that the heater hoses weren't hooked up when I bought it, being an Arizona car, didn't think much of it.  Now it is understood that the trans cooler wasn't hooked up and who knows for how long.  Maybe he didn't even reconnect after the trans rebuild in '78?  PO stopped driving it in '81 as reverse was acting up.  Makes some sense reverse would work better after the car was parked a bit to let things cool.
So would say the fluid has seen better days.  The heater hoses have melted on the shift arms.
Dave CLC#16900
1956 C 6237SDX ELS
1975 C 6CD47 CDV
Dave CLC#16900
I also am wondering if this is the original transmission to the car.  PO wasn't sure.  The last of my VIN is 53797, it was produced January 31, 1956.  Please see the best pictures I could muster of the Trans tag.  Kind of looks like F-56 68...  to me.
Dave CLC#16900
1956 C 6237SDX ELS
1975 C 6CD47 CDV
Dave CLC#16900
I had a parts car early 56 Seville, one of the ones that only said "Eldorado" on the front fenders.  I have the engine and transmission from that car.  If the current transmission doesn't match, would be easier to just send the spare transmission out for a rebuild.  That had car had 91,584 miles and was parked in the late 80s with severe rust issues.
Dave CLC#16900
1956 C 6237SDX ELS
1975 C 6CD47 CDV
Eldorado cars had a transmission with the suffix CE-001 to CE-11992. I cannot see the letters on your picture; the number 68 is a really early transmission...
Pontiac and Oldsmobile had basically the same transmission; the letter for Pontiac is "P" and could be "O" for Oldsmobile, but I'm not sure. Anyway, there were some exterior differences on those transmissions and I doubt that a Pontiac or Oldsmobile could be installed without modifications on a Cadillac.
TonyZappone #2624
Our dealereship had the machine that puts fresh transmission fluid in one place and pumps the old fluid out the other.  (excuse my mechanical ignorance as to what places).  30 years ago, I flushed the tranny on my '58 convertible, and one of my Derham limousines.  The limo is gone, but the '58 shifts like a new car.  I watched the dirty fluid coming out during the process.  It was really neat
Tony Zappone, #2624
1936 Pierce-Arrow conv sed
1947 Cadillac Conv cpe
1958 Cadillac conv
2025 Chrysler Pacifica Pinnacle
2016 Cadillac CT6 Platinum
Dave CLC#16900
#14
Hi Roger, makes more sense the F is actually an E.  Maybe this picture works better.  Was having a time trying to use my phone under the car, wasn't very high off the ground, just enough to get tires off.  Maybe this picture shows it better.  Seems odd that it would have a S/N that doesn't match the car and earlier than the car...
Dave CLC#16900
1956 C 6237SDX ELS
1975 C 6CD47 CDV
Dave CLC#16900
My parts car engine number is 5662008038.  I can't get to the trans tag at the moment but believe it matches.
Dave CLC#16900
1956 C 6237SDX ELS
1975 C 6CD47 CDV
Rather than an F or E, to me it looks like a 5.
Still cannot see the letter in front. It cannot be a "5", unless the operator did an error. It could be a "S" as there were special transmissions for 56: CS-56-1001 thru CS-56-1100. I don't know if those transmissions were used on Eldo models.
Unit number on the transmission does not match the engine (or VIN) number.
Quote from: Dave CLC#16900 on December 22, 2024, 07:20:14 PMHi Roger, makes more sense the F is actually an E.  Maybe this picture works better.  Was having a time trying to use my phone under the car, wasn't very high off the ground, just enough to get tires off.  Maybe this picture shows it better.  Seems odd that it would have a S/N that doesn't match the car and earlier than the car...
Put up on a large monitor, the lower numbers that are inscribed on the plate are "56 - 68".
Quote from: Big Fins on December 23, 2024, 04:36:39 AMPut up on a large monitor, the lower numbers that are inscribed on the plate are "56 - 68".
I can read those numbers too. Interesting are the letter(s) in front of the numbers!
The location of the plate is on the case's side, making it difficult to read. Later transmissions have to plate on the end face of the case; easier to read.
