What Thermostat 1960
Started by 60eldo, October 09, 2024, 07:29:23 PM
60eldo
 What thermostat are you guys running for year round driving.
Jon. Kluczynski
Jeff Rosansky CLC #28373
I don't know the brand, but the temp range is what is recommended for each engine.
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Michael Petti
I am using a 180 degree thermostat.
59-in-pieces
Jon,
I have likely asked this before, but don't you have a Service Manual for your car.
It is important to note that once you determine the temperature - 185 seems a bit high according to the literature - you should take care in selecting the proper radiator cap you use, depending if the car has AC or not. and how the thermostat is oriented when placed atop the water pump.
Have fun,
Steve B.
S. Butcher
60eldo
Steve I have a manual. My car is AC car, so my rad cap is 15 lbs. Just seeing what others are using.
Jon. Kluczynski
gkhashem
Jon, why ask? Use the recommended thermostat per the manual. I think it's a 180 degree one.
People think using a lower one makes the engine run cooler. THAT'S INCORRECT! All that does is allow the thermostat to open sooner.
This might be bad for the engine since it now takes longer for the car to get to the proper operating temperature. It does not prevent overheating as many people think.
Usually a car overheats because there is something else wrong, like a clogged radiator.
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
