Mechanical Fuel Pump
Started by Jim Miller, November 21, 2024, 05:43:48 PM
Jim Miller
You folks answered my question on the electric auxiliary fuel pump on the 57 I just purchased. Thanks!
Now on the mechanical pump. As I correct this, on the 57 does the glass bowl face up or down? I'm attempting to post a photo of how it is now with multiple brass fittings and the bowl lying sideways.
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2025 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
2021 XT6
Jim Miller
Here's the photo I was attempting to attach earlier
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2025 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
2021 XT6
Clewisiii
I cannot answer for your 57. I know this changed over time.
But here is a picture of the set up on 61. For AC cars they put a vapor return line on top. So the glass goes down.
Cadillac Jack 82
Please please please do not use rubber lines on the pressurized side of the pump!  That's asking for an engine fire.  I nearly lost my 59 because of a rubber hose failure.  if possible try and bend some hard line and replace that hose ASAP.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Cadillac Jack 82
Bowl always faces downward.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Clewisiii
Jim Miller
Quote from: Cadillac Jack 82 on November 21, 2024, 06:10:18 PMPlease please please do not use rubber lines on the pressurized side of the pump!  That's asking for an engine fire.  I nearly lost my 59 because of a rubber hose failure.  if possible try and bend some hard line and replace that hose ASAP.
Yes - I've ordered the metal lines
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2025 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
2021 XT6
Jon S
1957 faces up. Later years faced down:
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
dn010
#8
Photo of the engine in the 1957 shop manual on page 9-1 shows the filter bowl facing up.
I've seen the 57s with them installed both ways. Some facing up, some down, and sometimes with the filter removed altogether where they just ran a line from the pump to the filter. If you want to be "correct", go by the shop manual where it is facing up.
-----Dan B.
'81 DMC DeLorean
