1960s 1968 CAdillac 472 factory video
Started by jwwseville60, December 08, 2024, 08:35:26 AM
jwwseville60
Lifetime CLC
I had seen that and was going to post it but was unable to find it again on the computer I use for the forum.
One thing I'm curious about is what was this intended for?   The gaps and long animated fillers seem a bit odd.   At first I thought maybe it was to be used in conjunction with a live presentation and the gaps were when the live presenter would talk or perhaps a car would be driven on stage but the gaps don't really time out where that would make sense either.
I'm kinda thinking it was likely some endless loop cartridge system that was used in a semi portable display and could be set up at a convention or dealership sort of setting and each section would play on a loop, the hole punch in the solid red leader is a clue because that would have been a cue to the player to stop when it hit that.  There would then be a timer set to restart at a set interval or a push button activated by a presenter or even the general public to start the loop again.
The reason the cuts don't make sense is at some point someone took the film out of the cartridges and spliced them all together as a somewhat continuous program.  They may have had some damage before that process or were damaged in that process so there are little bits missing that would make each section seem more complete or a more natural stopping point.
Julien Abrahams
I get to a completely different video: an interview with a US navy rear admiral...
Did you mean this video:  https://youtu.be/hhsz1Char_c?feature=shared
1951 Buick Eight special
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
jwwseville60
Lifetime CLC
Gene Beaird
Skip to about the 1:35 mark if you want to avoid the snazzy '60's muzak.  Cool video, otherwise.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
Julien Abrahams
Yes, the 60's music and graphics is funny, but after about a minute I also had enough ;):D
1979 Opel Kadett
James Landi
#6
 T.J. wrote: "One thing I'm curious about is what was this intended for?   The gaps and long animated fillers seem a bit odd.   At first I thought maybe it was to be used in conjunction with a live presentation and the gaps were when the live presenter would talk or perhaps a car would be driven on stage but the gaps don't really time out where that would make sense either."
Stodgy tone deaf GM corporatists attempting to stay relevant during the psychedelic age of aquarius.
What the execs imagined was going to happen at the auto show that year....
"Hey dudes, I know we were headed to the VW booth but check out this crazy demo in the Cadillac booth, maybe we should all buy Fleetwoods instead of a VW bus".
