Disc brake conversion 1961 Series 62
Started by Caddygranddaddy, December 13, 2024, 09:40:18 PM
Cadman-iac
Quote from: Roger Zimmermann on December 22, 2024, 02:37:41 AMYes: 1958.
  I wasn't aware of that, you wouldn't have any pictures of one would you?
 Rick
CLC# 32373
Sorry, Rick: no picture as I don't own a '58. But the drawing from the shop manual may help.
Cadman-iac
Quote from: Roger Zimmermann on December 22, 2024, 12:04:33 PMSorry, Rick: no picture as I don't own a '58. But the drawing from the shop manual may help.
And I thought the 56 setup was weird! I've never seen such a setup as this one before.
So does the master cylinder sit on the top and the booster rod pushes from underneath it?
 When the master cylinder leaks on this system it's sure to ruin the booster.
I'll bet those are really hard to find anymore.
Thanks Roger.
CLC# 32373
Quote from: Cadman-iac on December 22, 2024, 01:11:16 PMWhen the master cylinder leaks on this system it's sure to ruin the booster.
You are welcome Rick!
That's right, when the master cylinder is leaking, the fluid is going down to the power piston. However, this situation is not much better with the '56 system, if leaking the fluid is getting also on the power piston...It will not get destroyed, unless you let is that way for a too long time and the cylinder is rusting. It's the same disease for both years!
Is the booster body cast or stamped?   I suppose it doesn't matter since brake fluid will eat either one.
