472 500 Valve Lifter Disassembly and Cleaning
Started by impalamansgarage, January 06, 2025, 08:26:56 PM
impalamansgarage
The lifters finally arrived at the cam grinder shop on Monday (Jan 27), so I'm waiting for a call
on progress. Meanwhile I've pulled the heads and they are at a local machine shop getting
cleaned up. They'll check flatness and mill if needed. I sent the bare heads only and lapped all
of the valves before dropping them off. Progress !
impalamansgarage
https://www.youtube.com/c/impalamansgarage
1971 CDV
1981 CDV (Sold)
1992 SDV (Sold)
1963 Fleetwood (Teenage Junker Project - Sold)
impalamansgarage
Well the lifters came back from the cam grinders shop and they basically look brand new. Right now I'm reassembling the engine and will hopefully fire it up this coming weekend. I decided to replace the camshaft with an after market model which is only slightly beefier than that the stock one. We'll see what we get !
impalamansgarage
1971 CDV
1981 CDV (Sold)
1992 SDV (Sold)
impalamansgarage
Well the motor is back together and she runs fine. After I doing a little steering and AC work, she'll back back on the road. The refurbished original lifters seem to be working well with the new cam.
impalamansgarage
1971 CDV
1981 CDV (Sold)
1992 SDV (Sold)
Congratulations.   With the proper running-in, you should have many miles of beautiful motoring.
