1973 Coupe Deville Horn Issue
Started by 34837, January 06, 2025, 09:12:01 PM
34837
Long story short, Horn (s?)were working when car purchased, suddenly not, determined not relay system, took to shop (foolishly but free); testing quickly ascertained all three units are dead.
  Utube informs me disassembling, cleaning contacts etc will solve the problem, worst part is going be grinding, drilling the rivets out.
  Has anyone cleaned these up with success?  Purchasing NOS is cost prohibitive, junkyard probably same problems.
Although always garaged the car spent first 7 years and first 36000 in Seattle, air couldn't have helped.
   Installed a $10 Amazon Horn temporarily, now I sound like an old Toyota. Thanks, A
Julien Abrahams
When I had two seemingly dead horns on a '66 Eldorado. I sprayed WD40 inside the horn (literally in the opening). Then let it sit for a couple of days. Tested them, and they now both work fine.
I would also test them with a good battery, connecting it directly with jumper leads.
1951 Buick Eight special
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
