1949 Shock rebuild
Started by Phil J, January 18, 2025, 08:42:18 AM
Phil J
Looking for a source to have my shocks rebuilt on my 49.  Thank you
Phil Jakubowski
1964 Deville Convertible
1957 Cadillac Custom motorhome
1949 Club coupe
J. Russo
Apple Hydraulics rebuilt the front and rear on my '41
They are in NY.
John Russo
CLC Member #32828
Carfreak
I second Apple Hydraulics. They've rebuilt lever action shocks for a few of our cars.
Very satisfied with the results.
Jay Friedman
The length and angle of the arm on '49 shocks determines the wheel alignment camber. Sometimes to speed things up Apple will suggest you exchange your shocks for a rebuilt pair they have in stock.  This is risky because the shock arms from different years (and make. Olds for example) can superficially look the same but have small differences which will make wheel alignment afterward difficult. So make sure you have Apple rebuild yours rather than exchange them, even though it may take longer to do. This once happened to me and caused lots of problems which took a while to solve.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Jim Miller
Apple rebuilt the shocks on my '41 in 2018 and last year rebuilt the rear shock links. Turn around time was not bad. About 10 days on the links.
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2025 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
2021 XT6
Cadillac Jack 82
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
TonyZappone #2624
Apple seems to be one of the most consistently good  companies that I have worked with over the last 60 years.  They have done shocks for me on a '41, a '47, and two Pierces
Tony Zappone, #2624
1936 Pierce-Arrow conv sed
1947 Cadillac Conv cpe
1958 Cadillac conv
2025 Chrysler Pacifica Pinnacle
2016 Cadillac CT6 Platinum
toybox
Getting the shocks rebuilt is no big deal. However, Getting the front end realigned is a little tricky. You should find someone Who knows how to do work on these types of suppensions. The first two I tried said they could and wouldn't listen to what I had to say about how to make adjustments my 46 and just wasted my time and money.Also be sure your fuel tank is full and your trunk has everything in it that you'll normaly carry ie spare ,jack and so on. this will make a big difference your caster setting. Tim
