1957 Questions
Started by Jim Miller, February 07, 2025, 05:20:31 PM
Jim Miller
I acquired a nice 57 sedan last fall. Two questions not really covered in the shop or authenticity manuals. From the water pump there are two coolant lines to the transmission and two to the heater core. These lines look like straight 5/8 hose with no moulded turns. Am I correct on this observation?
Then since there are four 5/8 lines coming out of the water pump, is that pump a one off? I believe they went to metal transmission cooling lines direct to the radiator in '58.
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2025 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
2021 XT6
1957 water pumps are one year only. For an unknown reason, the lower outlet connected to the radiator is on the passenger side. From 1949 to 1962, (except '57), the oultlet is on the driver side.
Jim Miller
Quote from: Roger Zimmermann on February 08, 2025, 11:45:21 AM1957 water pumps are one year only. For an unknown reason, the lower outlet connected to the radiator is on the passenger side. From 1949 to 1962, (except '57), the oultlet is on the driver side.
Thanks Roger
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2025 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
2021 XT6
Cadillac Jack 82
The 57 I had cooked one of the lines when in OC MD.  5/8s sounds right.  Had to have a local Shell station fix it.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Jim Miller
Quote from: Cadillac Jack 82 on February 08, 2025, 02:10:20 PMThe 57 I had cooked one of the lines when in OC MD.  5/8s sounds right.  Had to have a local Shell station fix it.
Mine are at least 25 years old. I've not put her up on the lift to see yet, but I'm hoping I can reach up to the heater core to the end of the hoses and not have to remove the dust shield. That core looks hard to reach up under the left fender.
Jim Miller
1941 6219
1949 6237X
1957 62 Sedan
1970 CDV
2025 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
2021 XT6
