1955 - What Is It?
Started by kadillackid, February 10, 2025, 03:10:17 PM
kadillackid
Anyone know what this electrical item is (highlighted in yellow)? It sits just below the neutral safety switch and is held in place by the same. The wire is tan (I think). Is it part of the horn circuit?
Saturnin15
If I remember correctly, it is for the horn. On the inner steering shaft, there's a thin brass sleeve with a wire soldered on it that goes up to the contact button under the horn ring.  So the connection you refer to is for some kind of contact that touch this brass sleeve.
Sedan Deville 1956
PHIL WHYTE CLC 14192
Quote from: kadillackid on February 10, 2025, 03:10:17 PMAnyone know what this electrical item is (highlighted in yellow)? It sits just below the neutral safety switch and is held in place by the same. The wire is tan (I think). Is it part of the horn circuit?
Yes it is the horn wire connection.
Lexi
I believe these 2 gents are correct. Clay/Lexi
David King (kz78hy)
It is the horn junction.  The wire is inside the column and is soldered to a round brass cylinder on the lower end of the steering shaft.  There is a spring loaded brass connector that loads through the top side of the lower steering column and it rides on the brass cylinder and the wire harness connects to it completing the electrical circuit.
I have made up a replacement part for these.  The bak-o-lite housing brakes on the originals.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Cadillac Jack 82
Horn contact.  Similar to other GM makes.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
kadillackid
