Should I replace my exhaust manifold cross over
Started by Daffer, March 12, 2025, 10:39:29 PM
Daffer
Just looking for some opinions on this. I was wondering if I should have a new one made or just paint this one? there are no holes, quite a bit of surface rust which is very stubborn even after sandblasting.
-Joshua
Jay Friedman
My opinion is that you leave it as is as long as it is not leaking.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Is this for looking at or driving?   Even if you find a shop that can do the job is the current material going to be as good and long lasting as the old stuff?
Daffer
Quote from: TJ Hopland on March 13, 2025, 11:28:26 AMIs this for looking at or driving?   Even if you find a shop that can do the job is the current material going to be as good and long lasting as the old stuff?
Yea that's true,  not sure what material this is made out of but I know a new one would be aluminum
Quote from: Daffer on March 13, 2025, 11:31:07 AMYea that's true,  not sure what material this is made out of but I know a new one would be aluminum
Aluminum for an exhaust system? It won't last a lot! Maybe you are thinking stainless steel, which the way to go.
Daffer
Quote from: Roger Zimmermann on March 13, 2025, 12:03:14 PMAluminum for an exhaust system? It won't last a lot! Maybe you are thinking stainless steel, which the way to go.
Your probably right im no expert when it comes to the exhaust system. But I'll remember that when the time comes fir a new exhaust because that's gone completely rusted away. That's why I was going back and fourth on weather or not to replace the cross over. I may give sandblasting another try then paint it to protect it. Unless advised otherwise
