1957 Pedal and TV adjustment help
Started by usnfarmall, March 28, 2025, 12:44:30 PM
usnfarmall
In the procedure for both it states, "Place a 1/4" drill/rod through the gauging hole in dash relay lever".  Call me dumb but what does this refer to and their locations?
1957 Special 60
David King (kz78hy)
The linkage on the dash panel where the rod comes up from the pedal and pivots to the carb.  There are holes there to stick the drill (0.250) through to zero out the 2 rods.  You will likely have to create slack in the carb rod so you can get the drill through and then start the process.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
usnfarmall
David,
Thanks for the information, ill look in to it soon.
1957 Special 60
dadscad
This is a photo of a 64 throttle relay lever. The hole for the quarter inch drill is lined up. Your relay should be similar to this one.
Enjoy The Ride,
David Thomas CLC #14765
1963 Coupe deVille
When I had my first Cadillac, about 40 years ago, I did not understand why this strange operation was needed and always skipped it. Until I had a dash pod which was functioning (you see it on the above picture). The plunger from the dash pod retracts with vacuum; when the engine is not running, the plunger is pushed by a stong spring and open slightly the throttle. However, for some adjustment, the throttle must be completely closed; with a correctly functioning and adjusted dash pod, the insertion of a drill bit is necessary to avoid wrong adjustment.
usnfarmall
Wow thanks for update and photos. Damn rain all weekend again so will have to wait. I'm now running an eldelbrock son not much need for the throttle relay but will keep the linkage the same.
1957 Special 60
Set the Edelbrock up in the same manner as the AFB. They are essentially the same thing. You had to use the throttle and TV rod attaching plate when you changed it over. Most Edelbrocks didn't come with the specific plate that mounts to the side of the throttle actuator.
