Strange noise after cold start ('66 Eldorado)
Started by Julien Abrahams, April 08, 2025, 01:18:24 AM
Julien Abrahams
A friend of mine has a '66;Eldorado that I got running and driving last year after being in storage for almost 30 years.Car runs well, but now has developed a strange noise that appears sometimes after a cold start. It goes away after about 5 mins of running.
He made a video for me to have a listen. I find the noise pretty strange. It is a california car, so it has the A.I.R. system. What could this be?
1951 Buick Eight special
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
Julien Abrahams
The AC is off. The AC is most likely not charged anymore, and compressor is not locked. I believe the compressor electrical connection is disconnected.
1979 Opel Kadett
Jeff Rosansky CLC #28373
I don't see a video, but what does it sound like? Ticking, rubbing, buzzing, hissing?
Both sides, front/rear?
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Julien Abrahams
I reposted the video, so hopefully it works now.
It is more like a swooshing, grinding noise. Hard to explain.
1979 Opel Kadett
From what I hear Just sounds like a motor with a few miles on it warming up.
Cadillac Jack 82
Sounds almost like the fan blade striking the radiator.  That's definitely not an engine noise.
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
I would agree, not an internal engine issue.  Frequency seems a little high but how about the 'heat riser' valve?
Disconnect the belts one at a time and listen to it. That sounds like an alternator bearing or water pump bearing. Does it have an A.I.R. pump on it?
The engine itself sounds normal. I wouldn't touch that. It's an accessory or maybe even the torque converter, by the whirring sound it makes.
Michael Petti
Just a thought, but could your fan blades be hitting the transmission cooling lines when cold?
Julien Abrahams
Good suggestions that we can try. After listening a couple more times I also was thinking something in the line of bearing issue i the A.I.R. pump. Removing the belts one by one would be a good way to isolate the problem. Not sure about the fan blades.How to check if it is coming from the torque converter?
1979 Opel Kadett
Michael Petti
The tranmission lines and/or their metal ends will show wear spots.
