Brake booster washers flat or lock?
Started by dbzsjones, April 26, 2025, 04:58:25 PM
dbzsjones
I just got my booster back from Karps Power Brake Service, and it looks great, but it came back without the mounting hardware. Off to the store for 4 3/8-24 nuts, but should I be getting flat or lock washers?
Clewisiii
dbzsjones
  I wasn't specific enough, I'm looking for what goes behind the firewall and holds the booster to the firewall.
Del
Clewisiii
I cannot remember if these are the same nuts that hold the entire brake pedal assembly to the firewall. That is packed away. I might be able to get a glimps in my parts car. But the inside is trashed right now.
Later I think it was common to use the type where the toothed washer is part of the nut. Not sure if those had a name, I suspect the name depended on the brand.
dbzsjones
The booster came back with 1 of the 4 nuts on it and it was a normal nut, but it could have been whatever the rebuilding had lying on the bench to make sure the threads were clean after the plating.
Clewisiii
Looks like what I always heard called a 'Stover locknut'.   I would guess thats a brand name, not sure if they are still around or not.
Clewisiii
Stover nuts can still be found. Just not everywhere. Uses a deformation in the thread to lock in place.
dbzsjones
Stover lock nut no washer it is, thanks for the help!
Given the location and visibility of the nuts, and availability considerations, I may settle for a nylock nut.
59-in-pieces
Del,
Here is a close-up of the interior nuts and toothed washer used in a 59.
Hope this helps.  (expand the picture to see the teeth more clearly, but they are there)
Have fun,
Steve B.
S. Butcher
#11
Quote from: TJ Hopland on April 28, 2025, 10:56:16 AMLater I think it was common to use the type where the toothed washer is part of the nut. Not sure if those had a name, I suspect the name depended on the brand.
They do have a name, they are called KEP nuts, you can Google that name on the internet and get a large variety of same.  FWIW, if that were my booster, I would use flat washers and nylock nuts.  Not a big deal unless it is a show car and you think the judges will look under the dash to see what kind of fasteners you used.   :)
tcom2027
Flange or flanged nut.
tony
dbzsjones
Thanks all, not a show car so not worried about a judge sticking his head under the dash, just wanted to make sure I attached it appropriately.  So it looks like locking nuts are the theme, with a preference for KEP or Stover.  I do have a latent AR tendency that wants to get things as close to authentic as possible even if it's not a show car.
59-in-pieces
Del,
The toothed washer is OEM - and cheaper, but who am I to get involved in such a life changing, earth shaking decision.
Have fun,
Steve B.
S. Butcher
dbzsjones
Cheaper and more accurate!  How often does that happen in this hobby?  Must be my lucky day.
