1960-62 Transmission piece
Started by 60eldo, May 10, 2025, 10:04:00 AM
60eldo
  Can someone tell me if this part of a 1962 trans is the same as my 1960? Cause I lost my 60 part, and so I cant match them up. Had my trans rebuilt last year and now this piece broke at the weld. Its located on driver side goes to TV rod . Theres a pic in the 1960 shop manuel  page 6-3,,,,they are called  manuel lever and  Outer TV lever in fig 6-4
Jon. Kluczynski
You have luck: the throttle lever and the shift control lever are used (with the same resp. part number) from 1960 to 1963 (64 for some models).
60eldo
  Thank you, Cause if it wouldnt fit, I dont no where I would find one.
Jon. Kluczynski
