1960 Convertible Side body trim attach hole location. Rear Panel
Started by hmbmw21, May 14, 2025, 10:44:39 AM
hmbmw21
Good morning, Does anyone have a side body trim attach hole location points my car did not have because previous owner fill with body filler and the trim was not installed Ive picked up hole markings on front fender&door side but need for the quarter panel and above rear fender skirts. Thank you for the help!!  Harry CLC 34337.
Moody
The holes should be easily found inside the trunk, and behind the inside panels. These are installed with small nuts. The clips over the skirts are push in style clips, with no inside access. These could prove to be difficult if they've been filled in.
Moody
Moody
Also, the moldings should have the attach hardware installed, which will give you the locations.
Moody
hmbmw21
Yes, I"m trying to hole location right above rear quarter panel right above rear fender wheel well and skirt ,It's diffcult because I had to replace quarter panel. Thank you for the help.
Moody
Moody
hmbmw21
