1950 Cadillac ignition positions
Started by Cadillac Jack 82, May 20, 2025, 11:31:19 AM
Cadillac Jack 82
I feel stupid for asking this, but, does anyone have the ignition switch positions for a 1950 Cadillac?  Currently I have it at the in between 1 and 2 o'clock position which I assume is "Off".  I typically have to turn it to the 3 o'clock position to start.  I just want to make sure I don't keep the car in "ACC" and drain the battery.  Can anyone here provide some guidance?
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Shooting from the hip because I don't 100% know.
11:00 ACC
12:00 OFF
13:00 ON
14:00 START
Cadillac Jack 82
Thanks BigFins.  There are only 3 positions.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
dn010
#4
Any ignition I've ever seen, the off is always 12, straight up & down. The only time I've seen it turned past that point while "off" is when the ignition switch turned inside the dashboard due to a worn out notch from past parties trying to crank down on the key to start for some reason.
I'm not sure if the dash needles come alive on acc position, maybe that is a way to tell?
-----Dan B.
'81 DMC DeLorean
Did Cadillac use different keys and such than other GM's?   Didn't they come from Briggs & Stratton?   Later 50's they had a ACC and I too would say that was 11:00 and I think there is supposed to be some sort of gate where you have to push in a bit to get it to acc.   Seems like when I'm not trying it easily goes into ACC but if I want it too I can't do it.  And at least on the ones I tangled with you can remove the key in ACC
Jay Friedman
I thi
Quote from: Cadillac Jack 82 on May 20, 2025, 11:31:19 AMI feel stupid for asking this, but, does anyone have the ignition switch positions for a 1950 Cadillac?  Currently I have it at the in between 1 and 2 o'clock position which I assume is "Off".  I typically have to turn it to the 3 o'clock position to start.  I just want to make sure I don't keep the car in "ACC" and drain the battery.  Can anyone here provide some guidance?
I think your ignition switch is the same as my 1949's. You start the motor by pressing a button, right?
If so, there are 3 positions on the ignition switch: ACC to the left; OFF in the middle; ON to the right.  I think your ignition switch is merely turned around a bit to the right in the hole in the dash it is mounted in.  You'll notice there is a "collar" around the switch with little round depressions in it.  This is a nut which locks the ignition switch in place.  Loosen it by tapping in one of the depressions with a drift pin.  Unscrew it slightly and turn the switch a bit to the left so that the key is at 12 o'clock when the key is in the middle (OFF) position.  Tighten the collar with the drift pin or gently with a pliers and you are done.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Cadillac Jack 82
Awesome!  I was right!  Thank you Jay!
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
Jeff Rosansky CLC #28373
#8
Quote from: TJ Hopland on May 20, 2025, 03:51:50 PMDid Cadillac use different keys and such than other GM's?  Didn't they come from Briggs & Stratton?
Here is the set that came with our 55. I can't say they are original, but 1 side says GM, and the other says Briggs & Stratton.
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
