1962 engine and trans Pics now
Started by 60eldo, May 30, 2025, 09:18:08 AM
60eldo
 I may soon be getting a 62 engine, complete from pan to breather. PS pump. AC compressor , rebuilt gen, carb, but engine needs rebuild. Also the trany, its been rebuilt.
Jon. Kluczynski
Cadillac Jack 82
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
60eldo
It says in my post,,,,ITS REBUILT
Jon. Kluczynski
Cadillac Jack 82
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
60eldo
#4
Mechanic says it just blew a frost plug, who knows, but this may be a running engine. It was running 2 wks ago. Rochester carb
Jon. Kluczynski
60eldo
   Any offers will be considered
Jon. Kluczynski
It may be worth a good clean up and running it on a stand to see what you have. A complete gasket set could save you thousands in junk parts and machine shop costs. Unless you plan on keeping it another 50 years.
If you can find the disc brass freeze plugs, clean up the seats and JB Weld them in. The steel plugs for some reason seem to swell and shrink with the heat and blow themselves out under pressure. I lost 4 of them that way and they were put in and seated correctly. A small bead of JB Weld held them in with no issue. I also had a high volume Flow Kooler pump. It was overkill.
The seats have to be perfectly clean and free of pitting to get a good seal. You can also try red Loctite Thread Locker. That was suggested to me after I had put them back in with JB Weld. The bad part about that is, if they ever have to be removed again, the cup seats will have to be machined again.
bigoilman
Did it come with A/C compressor brackets?  I'd be interested in them if so.
CLC - #35118
60eldo
Are 60 the same cause I have a set of those
Jon. Kluczynski
