57 60 Special, hard shift
Started by usnfarmall, June 10, 2025, 03:38:02 PM
usnfarmall
My transmission seems normal in all gears, but when shifted from park to drive or reverse shifts extremely hard.  I was thinking that the idle rpm was too high, so I adjusted it to about 650.  Seemed to be a little better but not much.  I have read about all the post here about the transmission shifts but none relate to this specific topic.  I have checked the fluid and seems to be fine and to the correct level.  Is there any correlation between the TV shaft and this shift or does something else control this shift?  Maybe the rpms are set wrong but the manual does not clearly state the correct rpms at high idle, normal park idle and in gear idle.
1957 Special 60
Mike Baillargeon #15848
My 2 cents....I have a 1953 Buick that was doing what you describe...
Turned out the motor and the transmission mounts were shot....
The motor and the tranny moving around caused great chaos with the shift linkage...
I would start by eyeballing those mounts...
Baillargeon
#15848
Jon S
In addition to motor/transmission mounts it could be the driveshaft universal joints. Idle speed (hot) should be 525 RPMs.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
dn010
#3
Manual says RPM should be 420 on the single rochester or 520 on the dual carbs. 650 is too high. I have mine set as low as it will go without stalling, just to give my 68 year old transmission as much of a break as possible.
-----Dan B.
'81 DMC DeLorean
usnfarmall
Am I to assume that this is hot in gear?
1957 Special 60
dn010
Hot in drive. Page 10-19 if you have a manual.
-----Dan B.
'81 DMC DeLorean
usnfarmall
Yes I have the manual.  Thanks for all the info.
1957 Special 60
59-in-pieces
Steve,
How many miles does the mighty beast have on her.
Not saying this is it, but with lots of miles - or tough use - as with jack rabbit jumps from a stop - not you but in her earlier days, a trans can develop "slop" and aa speed increase the "lash' is caused by tightening up the "slop".
I'm also a fan of bad U-joints.
Have fun,
Steve B.
S. Butcher
usnfarmall
The best I could tell around 96K.
1957 Special 60
