1955 Eldorado transmission cooler
Started by jamesmundstock, June 17, 2025, 09:17:00 PM
jamesmundstock
I know the Harrison cooler mounts to the flange of the transmission pan. I also know one fluid tube connects to the side of the transmission case. Does the other tube connect to a fitting on the side of the transmission pan or is there another port?  I don't have access to crawl under mine to look at the connections so this is why I'm asking. Thanks in advance for the replies.
Jeff Rosansky CLC #28373
Just curious--
I didn't think the 55 had a cooler. Is it an Eldorado thing like the carbs? And/or is the Harrison cooler an aftermarket mod?
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Indeed, only Eldorado models had a transmission cooler.
jamesmundstock
1955 Cadillacs with dual Rochester carburetors had the Harrison transmission coolers and the commercial chassis also had the transmission coolers.
