Replacing the Power Steering belt 1959 Cadillac
Started by Cadillac Jack 82, June 24, 2025, 10:00:38 AM
Cadillac Jack 82
So the good news is that I'm able to replace the broken fuel pump with a Napa one.  Good enough for now until I can replace it with the correct AC pump.  While wrestling with the pump I popped the power steering belt off.  I see that theres two bolts on the back side of the pulley however the pump doesn't move once these are loosened and I'm unable to pop the belt back on.  Am I missing something here?
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Jeff Rosansky CLC #28373
I dont know on the 59, but look behind and low. There may be 1 more bolt from the back that acts as a hinge point.
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Clewisiii
For 61 there are two bolts on the bracket. The blue arrow goes to pivot point. The red arrow goes to adjustable bolt. These are hidden behind the pully.
Cadillac Jack 82
Quote from: Clewisiii on June 24, 2025, 01:25:05 PMFor 61 there are two bolts on the bracket. The blue arrow goes to pivot point. The red arrow goes to adjustable bolt. These are hidden behind the pully.
I think the bracket on a 59 is slightly different but I'll take a peek later today.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
dn010
#4
1959 should have three bolts, so you have one more to go to get it loose.
https://www.ebay.com/itm/326093942438
https://www.ebay.com/itm/285696489849
-----Dan B.
'81 DMC DeLorean
Cadillac Jack 82
Was able to get it loose and replace the belt.  Only problem now is I have a screeching noise on sharp turns.  Too tight?
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
dn010
Probably too loose. Does it happen when you turn the wheel to full lock while stopped in the driveway?
-----Dan B.
'81 DMC DeLorean
Cadillac Jack 82
Interestingly enough it only made the noise for the first mile or so then seemed to die out.  I'm wondering if it was a pressure issue?  In any case it seems fine now.  If it continues, I'll tighten the belt further using the method provided above.
CLC Member #30850
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1964 Cadillac SDV
David King (kz78hy)
Ensure the fluid level in the pump reservoir is full.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
With screeching belts, make sure that you have the correct "V" shaped belt for the pulley.
The screeching occurs when the belt is running too shallower belt, and the sides of the "V" are not fully engaging the "V" in the pulleys, as in the bottom of the belt riding on the bottom of the pulley.
Lastly, ensure that the sides of the belt are not contaminated with oil or grease, with the same for the pulley.
