1966 A/c Compressor Belt Size and Routing
Started by Robert Green, July 17, 2025, 06:15:40 PM
Robert Green
Hi All,
I'm replacing the engine belts on my '66 Eldorado; it's an a/c non California car. The alternator drive belt had snapped so it seemed sensible to change everything else at the same time.
I ordered a replacement set from Caddy Daddy and have noticed that, in the case of the replacement belt for the a/c compressor drive, there is a significant difference in size from the belt already on the car.
My existing belt has a size code of 15560 with an outside circumference of around 56.7inches, and is routed to spool over both the water pump/fan pulley and crankcase pulleys as well as the compressor.
However the Caddy Daddy replacement (size code 7435) has an outside circumference of only 44 inches odd, and would I guess only spool over the front groove of the water pump/fan pulley, leaving the front groove of the crankcase pulley unused.
The Cadillac shop manual doesn't show belt routing or specify belt dimensions (as far as I can see), and Rock Auto list both the longer and shorter belt sizes for the '66 a/c compressor belt.
So which is the correct belt size and routing?
Also if anyone has experience with the different belt brands I'd  very interested to hear.
Many thanks,
Robert Green
Rhodes
I spent weeks trying to find the "super special" unique extra wide A/C belt for a mid '70s Cadillac 500ci, because the typical .5" belts just isn't enough--allegedly.
Well I never found part numbers, I never found special dimensions, and as of now I'm going to run a Dayco 17625.
I think you may have a hard time finding these special "wide AC belts"
