40 & earlier lifter plungers interchange
Started by Bob Hoffmann CLC#96, July 26, 2025, 05:35:01 PM
Bob Hoffmann CLC#96
What is the difference between the 40 & earlier lifter plungers & the 41 & later ones. Will they interchange??
Thanks, Bob
Warren Rauch #4286
      Cadillac Serviceman March-April 1944 page 8
     There is a nice illustration of both types and some dimensions.
      The difference is in the body length of the larger diameter part of the plunger.
       1936-40 is 1 7/64 inches
       1941-early 48 is 59/64 inches
      The body part that the plunger fits in also different
       1936-40  is 1 3/32 inches long for the counterbore for the plunger
       1941-early48  is 29/32 inches"  "   "    "          "    "   "
     The parts books are clear you can't mix them. They are not clear if you use both plunger and body whether the unit will interchange.
Warren
harry s
My understanding is the complete lifer assembly will interchange for all years but the individual components will not. I used a complete set of third generation lifters for the late '48s in a '39 LaSalle which worked fine.    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Bob Hoffmann CLC#96
Does that mean using the early bodies to go with the early plungers?
Warren Rauch #4286
      That is exactly what that means, Bob. The early bodies must be used with the early plungers.
   There were three types of lifters used from 1936-48. I'll call them types 1-2-3.From what Harry did we know they interchange as sets.
         Type 1 1936-40  Plunger and body separate
         type 2  1941- early1948  Plunger and body separate
         type 3  late 1948   Unit type   plunger and body one piece
The plunger/body types are counterbored to different depths,so they must match. To work.
Warren
Bob Hoffmann CLC#96
