Glue for 1979 emblems
Started by Jeff Rosansky CLC #28373, August 11, 2025, 11:30:05 AM
Hello,
I guess the heat got to our 79 and the black glue that holds the V on the trunk has given up.
What glue did they use to attach those emblems back in the day, or what is everyone using to reattach them now?
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Eric DeVirgilis CLC# 8621
Clean off all the disintegrated material from the emblem and decklid and apply 3M double sided adhesive foam tape to the V emblem. Have a fresh razor handy to trim the tape to the outline of the emblem. DO NOT USE GLUE! Foam tape is how it was attached at the factory.
Quote from: Eric DeVirgilis CLC# 8621 on August 11, 2025, 11:37:53 AMClean off all the disintegrated material from the emblem and decklid and apply 3M double sided adhesive foam tape to the V emblem. Have a fresh razor handy to trim the tape to the outline of the emblem. DO NOT USE GLUE! Foam tape is how it was attached at the factory.
Jeff Rose
CLC #28373
https://www.amazon.com/dp/B0016HM7SE?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
I hope the link works. I was logged in.
Good stuff so far as I see. I'm ready to try it on a few more things. Easy to work with but tacky as h*ll. You stick it and it's stuck.
