Anyone got HGBV adjustment experience with modern refrigerants?
Started by bigoilman, Yesterday at 03:49:38 PM
1 Member and 1 Guest are viewing this topic.
bigoilman
I rebuilt mine but adjusting it makes little difference to the pressures. I got it down to 47# (spec is 30#) but that's all it'll do.  I'm using Envirosafe and the pressures should actually be lower than R12 or R134a specs but it's not happening.
System is blowing mid-high 40s air.  Maybe I'm expecting too much?  I'm used to getting low 40s output.
I added a 16" Spal pusher fan to the condenser too.
CLC - #35118
