Master cylinder Top
Started by Upnorth, August 29, 2025, 11:40:32 AM
Upnorth
Good morning I appear to be suffering from a extremely stuck master cylinder cap on my 1947 Series 62.
One issue is I cannot seem to find a wrench to fit the bolt  I thought it was 11/16
Also even with vice grips etc. it will not budge any thoughts on my dilemma would be most helpful , I would like to avoid removing it from the car.
If I do have to take it off are there and tricks on opening bleeders and bleeding the brakes
Thank you  Up North
harry s
Some of the caps are cast material and will break with too much pressure. I would try soaking with PB Blaster and using an adjustable wrench. If that doesn't work it would be best to remove and drain so you can use some heat. As far as bleeding be sure not to let fluid drain from the lines and then bleed at the line connection after re installing. Good Luck   Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
