Throttle sticking on flathead
Started by Tom Boehm, Yesterday at 02:59:20 PM
Tom Boehm
The RPM's don't go down when I take my foot off the pedal on my 1940 Lasalle. I have to tap the pedal to get the RPM's to go down. I tried spraying WD-40 on the linkages on the outside of the carburetor. That helped a little. I already have two of the factory original return springs on the linkage. What causes this?
1940 Lasalle 50 series
Jay Friedman
Could be that the bushings/bearings on which the butterfly valve rotates are faulty. Carburetor rebuilders can fix these.  I would also suggest you take apart the various components of the linkage and apply lithium grease to the swivel points.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
harry s
In addition to Jay's recommendation check the hand throttle connection.    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Tom Boehm
#3
Here is a picture of my Lasalle from today. Not finished yet. Dashboard and hand throttle cable not installed yet. Engine and carburetor rebuilt years ago. Car is drivable but doesn't get driven much. Seats 2024. Front doors built this spring. Hopefully back doors this fall. Looking for a bodyman/painter in Louisville Ky metro.
J. Russo
John Russo
CLC Member #32828
