Steering colume interchangability
Started by Steve B, January 11, 2005, 01:13:10 PM
Steve B
Can someone tell me, -Will a colume from a 70 Eldo bolt into a 70 Sedan Deville?  Thanks -Steve
Mike #19861
 While GM columns are very similar, and almost identical in many respects, there can me minute differances in length and mounting hardware. I do know that a column from the same body type are generally interchagible, i.e. C-bodies such as deVilles and say an Olds 98, or even from C to B bodies. The swap from a C-body to an E-body such as your Eldorado may not line up perfectly.
 The best thing to do is to place both columns side by side and inspect them and take measurements.
Robt.Vonheck via a drenched SanDiego Calif.
--also, you can check with a major autowrecker/dismanteler and ask them to check their parts-interchangability Book!!  Particularly try for a boneyard that deals exclusively in cadillacs...   ~Bob vH
