Prime oil pump
Started by Ted Miller, March 11, 2005, 10:13:49 PM
Ted Miller
I need to prime my oil pump on my 500, is the procedure basically the same as on a Chevrolet?  Ted
Michael Stamps 19507
I have an adapted old distro drive that you can chuck up with an electic drill.  You can also pack the oil pump with vasoline in order to make sure it primes.
Stampie
Joe G CLC 12138
I just went through this last year. I had a 500 that was hard to prime, even with the Distributor Shaft Adapter. The Shop manual says to remove oil pump, and pack with Vaseline. Re-install. It worked well.
Ted Miller
Thanks for the tip guys.  I guess I will start the process in the morning.  Ted
