Installing Freeze-Out Plugs-37 Caddy
Started by Joseph P. McCormick, #14142, March 31, 2005, 09:06:20 AM
Which way are the plugs installed?  Is the raised center toward the engine or the other way?  Thanks, Joe
Harry Scott
Joe, With all surfaces clean and smooth install them with the curve outward. It is a good idea to put some sealant on the edges. Then strike the raised center with a ballpean hammer or a punch. This makes the plug expand and seal. Good Luck
Joseph P. McCormick #14142
Hello Harry,  Thank you very much for you reply. I will install the freeze out plugs that way.  Joe
