engine weight
Started by baxter culver #17184, January 25, 2006, 02:44:06 PM
Can anyone tell me what the flathead (346 cu in) engine weighs?  Also, the same for the early 331 cu in o/h valve engine?
Jeff Maltby #4194
Breakdown:
1948 vrs 1949 stat component breakdown=
1. Block-case 303.2 lbs-1949 191.7 lbs
2. Cylinder heads 77.2-1949 93.8 lbs
3. Clutch & flywheel housing 39.4 lbs-1949 30.7 lbs
4. Crankshaft 92.4 lbs-1949 61.6 lbs
5. Flywheel 50.3-1949 33.4 lbs
6. Rods & pistons 31.3 lbs-1949 26.9 lbs
7. Intake-exhaust manifolds 64.4 lbs-1949 52.2 lbs
8. Total engine dry 886.9-1949 699.1
9. Radiator core & tank 40.0-1949 25.6
10.Total engine & radiator wet 992.4 lbs-1949 771.7
Gleamed from the June-July 1972 Special Interest Autos mag (reprint sia #11=out of print for many years) 1948 vrs 1949 fastback shootout. The 48 coupe won.
Thank you Jeff!
This is the kind of response that proves the value of being a member of the CLC and having the resources of so many individual Cadillac/LaSalle owners at hand.
Porter 21919
Engine Weight FYI
by Dave Williams
dave.williams@chaos.lrk.ar.us
version 93.11.14
It isnt really a Frequently Asked Question, so Ill call it an FYI,
For
Your Information. This was originally a list Id compiled long ago on
paper, then moved to the computer, then posted on the net as a response
to
some questions. It wound up being popular, but since I didnt keep track
of
the origin of the data there was some debate as to how accurate the list
was. This new improved list has origins where I could find references;
what
doesnt have an origin is stuff from my original list.
Youll sometimes see more than one weight listed. Some weights are for
just
a long block, some are complete and ready to run, and of course
everything
in between. Some engines varied in weight during their production runs -
for example, some later Chevy V8s use thinwall blocks and aluminum
heads.
If you have any figures youd like to contribute, please send them to me
at
the email address above.
                         Weight
          engine                References     Comments
                         pounds
 Alfasud flat-4          240    (2) (Possible AC use PL)
 Alfa Romeo SOHC V6      375    (2)
 AMC V8                  540            (one ref showed 600)
 AMC 6                   500
 Audi 2.0 L4             335    (2)
 Audi 5                  364    (2)        (non-turbo)
 Audi 80 1300            230    (2)
 Audi 100 1500           240    (2)
 Austin C-series L6      562    (2) (56 Austin-Healey 100-6)
 BL B L4 OHV           335    (2)
 BL E L6               345    (2)        (complete)
 BL O L4 OHC           298    (2)
 BMW M52 3.3,3.5 Big Six 500    (2)
 BMW M60 Small Six       388    (2)
 BMW slant-6 turbodiesel 430
 BMW 4.5L V12            607    (2)
 BMW M105 Diesel 6 2.5L  430    (4)
 Buick 350               450
 Buick 401               685    (1)     (59 Nail Head)
 Buick 430-455 V8        600            (one ref showed 640)
 Buick 1963 odd-fire V6  414    (2)
 Buick V6                375 (Racing parts avail. Possible AC use PL)
 Buick 3.0 V6 85-up     350
 Buick/Rover/Olds 215 V8 318 (Of Swift & E-racer fame PL)
 Buick 1961 215 V8       324    (2)
 Cadillac V8 390         720    (1)        (59)
 Cadillac V8 472-500     625   (Popular in air boats PL)
 Cadillac V-16           1,300  (2)        (1931)
 Cadillac 331 V8         699    (2)        (1949)
 Chevy Corvair flat 6    300   (Lots used in Pietenpols PL)
 Chevy 1.8-2.0 L4        302    (4)        J car pushrod
 Chevy Chevette 1.6 SOHC 300    (4)        (also Opel)
 Chevy Vega L4           285
 Chevy II 153 L4         350
 Chevy L6 194-250        440
 Chevy L6 292            ---
 Chevy L6 216/235        630    (2)
 Chevy V6-90 229, 4.3    425  (Infamous Belted Power eng. PL)
 Chevy V6-60 2.8, 3.1    350    (2)
 Chevy small block V8    575        (generic for 60s-70s motors)
 Chevy small block V8    535    (1) (59 Corvette 283 w/alum.intake)
 Chevy V8 348/409        620    (1)
 Chevy big block V8      685               Mark IV
 Chevy big block V8      ---               Mark V
 Chrysler 2.2 L4         216    (6)        (bare motor)
 Chrysler 413 wedge      640    (1)        (59 300-E)
 Chrysler 331 Hemi       745    (5)        1955
 Citroen 2.0 Douvrin 4   263
 DeSoto 383              630    (1)        (59)
 DeSoto V8               675    (5)        (276-341 CID, 50s)
 Dodge V8                645    (5)        (241-325 CID, 50s)
 Dodge 361               625    (1)        (59)
 Edsel 361               680    (1)        (59)
 Ferrari 312T            397    (2)  (V12 3.0L racing engine)
 Ferrari 250 V12       382    (2)
 FIAT/Ferrari Dino V6    285    (2)        (model 206)
 FIAT/Ferrari Dino V6    296    (2)        (model 246)
 Ford Kent 1600          ---
 Ford Escort OHC 1600    ---
 Ford 1.3-2.0 OHC        ---
 Ford 2.3 Lima/Pinto L4  418    (2)        (also 2.0, 2.5)
 Ford 2.3 Lima/Pinto L4  450    (2)        (turbo)
 Ford Germany Taunus V4  205    (2)        (and SAAB V4)
 Ford England Essex V4   327
 Ford Germany 2.0-2.8 V6 305
 Ford England Essex V6   379    (2)        (3 liter)
 Ford 3.8 V6-90          351 (4) W/start, alt, L/clutch (used in AC PL)
 Ford 170-250 L6         385  (except Australian w/aluminum head)
 Ford 240-300 L6         ---
 Ford flathead V8        525
 Ford flathead V8        569    (1)    (53 239 CID)
 Ford Cosworth DFV       353    (2)  (racing engine, DOHC, 3.0L)
 Ford SOHC modular V8    ---
 Ford DOHC modular V8    ---
 Ford 255 Windsor        468    (4)
 Ford 289/302 V8         460     (late 5.0s are a bit lighter)
 Ford BOSS 302           500
 Ford 351 Cleveland      550  (includes BOSS and Australian 302-C)
 Ford 351 Windsor        510
 Ford Y block V8         625            (272-312 CID)
 Ford FE big block       650            (332-428 CID)
 Ford FE big block       670    (1)     (59 352 CID)
 Ford 429/460 V8         640
 Ford BOSS 429           680   (iron block, aluminum heads)
 Isuzu 1.8 Diesel L4     384    (4)
 Isuzu 1.8 gas L4        311    (4)
 Jaguar old design 6     ---
 Jaguar new design 6     ---
 Jaguar V12              680
 Lincoln 430             740    (1)        (59) (also Mercury 430)
 Lotus 907 (Esprit)      275    (3)(inc. alt. & starter, no clutch)
 Marmon V-16             931    (2)        (1931)
 Mercedes SOHC V8 alum.  452    (2) (possible AC potential PL)
 Mercedes SOHC V8 iron   540    (2)
 Mopar Slant Six         475
 Mopar 273-340 A V8    525
 Mopar 360 A           550
 Mopar 361-383-400 V8    620    (5)
 Mopar 413-426W-440 V8   670    (5)
 Mopar Street Hemi       765               (690 bare)
 Nissan 240-300Z 6       ---
 Nissan CA20 FWD         269    (4)        belt cam
 Nissan Z20 NAPS-Z 2.0   346    (4)        RWD chain cam
 Olds 215 V8             318    (same as Buick/Rover)
 Olds 260 V8             ---
 Olds 304 Rocket V8    671    (2)        first Olds V8, 1949
 Olds straight-8         614    (2)        40s motor
 Olds 330 J2             700               (first generation V8)
 Olds 330-400            560 (5) low deck, w/accessories, no flywheel
 Olds 350-403 V8         ---            86-up lightweight design
 Olds 394                725    (1)        (59)
 Olds 371, 394           760    (5)
 Olds 400-455            620 (5) high deck w/accessories, no flywheel
 Olds 262 V6 Diesel      590    (4)        (from GM SAE paper)
 Olds 260 Diesel         ---
 Olds 350 Diesel         ---
 Opel 2.8-3.0 CIH L6     395    (2)
 Peugeot 204 Diesel      272
 Peugeot Douvrin 2.0 4   263    (2)
 Peugeot 104 1400        260    (2)        includes transaxle
 Pierce-Arrow V-12       1,130  (2)        (1932)
 Plymouth 361            640    (1)        (59)
 Pontiac L4              350               Iron Duke, Tech IV
 Pontiac Tempest slant 4 470
 Pontiac SOHC 6          450
 Pontiac 389 V8          650
 Pontiac 389 V8          590    (1)        (59)
 Porsche 4.7 SOHC V8     574
 Porsche 901 6           401    (2)        (1963)
 Rambler 327 V8          600
 Rambler 327 V8          670    (1)        (59)
 Rover 3500 V8           318       (same as Buick/Olds)
 Rover 3.0 SOHC L6       432    (2)
 Renault 2.0 4 Douvrin   263    (2)
 Renault 2.8 V6          375    (2)  (also DeLorean, Peugeot, Volvo)
 Renault EF-1            395    (2)  (racing version of P-R-V V6)
 SAAB V4-60              206    (2) (also Taunus, Ford) (AC poten. PL)
 SAAB slant-4            290    (2)    (also Triumph)
 Studebaker 289          650
 Triumph 2, 2.2 L4       ???               [TR2-4]
 Triumph slant-4         290    (2)   (also SAAB 99) [TR7]
 Triumph 2, 2.5 L6       403    (2)        [TR6, GT6]
 Triumph Spitfire/Herald ???
 Triumph Stag V8         446
 VW flat-4 air cooled    200  (This number is too high PL)
 VW flat-4 water cooled  ---
 VW inline 4             ---           Rabbit/Golf
References:
  1. Handbook of Engine Swapping, John Thawley, 1960
  2. Complete Handbook of Automotive Power Trains, Jan Norbye, 1981
  3. Passenger Car Engines, papers, IMechE, 1975
  4. New Light Duty Engines, SAE 510, 1982
  5. Hot Rod Engines, Hot Rod, 1967
  6. Aspects of Internal Combustion Engine Design, SAE 582, 1982
Copyright 1989-1995 Team.Net
The editor of this page is Bob Haskell, ierh2@agt.gmeds.com
