1959 hose connection to heater
Started by Matthias #22137, March 05, 2006, 09:10:19 PM
Matthias #22137
hi folks,
currently I am restoring a 59 4window Sedan DeVille with AC, had the heater hoses which come from the water pump disconnected and dont remember anymore which one goes where. Outlet waterpump to upper or lower connector on heater core which sticks through the firewall?
Thanks for your help, Matthias
JIM CLC # 15000
03-05-06
Matthias,Just a WAG on my part. But I would go from the water-pump to the bottom hose connection on the heater core. Reason,  By connecting to the bottom of the heater-core you bleed the air from the heater core as it fills from the water-pump.
HTH Good Luck, Jim
