Correct battery cables for 66 Cadillac
Started by Greg McDonnell CLC #20841, March 09, 2006, 10:34:03 PM
In my effort to give the AACA judges very little to find incorrect about my 66 Eldorado, I want to make sure I have the absolute correct battery cables.  Is there somewhere in the data base that shows what the ends are supposed to look like?  My postive cable has an end with a bolt and nut through it to tighten it once it is slipped over the post.  The negative cable has a different end.  It appears to be an end that is pinched with a pair of pliers to tighten it around the post.  When it is closed, one piece fits in the middle of the other two and it tightens.  Which one (if either) is correct?
Thank you,
Greg McDonnell
