76 Seville Electric Sparks in Switches
Started by waterzap, February 10, 2012, 12:31:25 PM
waterzap
Hi guys,
Sometimes when I use some of the door switches, door locks, window switches, I can see small electrical sparks. Really only noticeable at night when I look “through” the switches.
I can also see some arcs coming from the AC switch when I operate it. I took out all the switches, took them apart and cleaned the inside. Still get the sparks.  Anything I can do or be concerned about? Everything works, just sparking.
Waldo
Leesburg, AL
mgbeda
Sounds normal to me for any switch controlling a motor- it has something to do with induction.  I recall reading in a Jaguar forum that some people wire up diodes to switches to prevent this from happening.  Supposed to make the switches last longer.  It sounds like a lot of work to me so I never bothered.  I can get you more details if you are interested...
-mB
-Mike Beda
CLC #24610
1976 Sedan DeVille (Bessie)
waterzap
Thanks for the info. If that is the case, and it is normal, I will just leave it. The switches did not look too bad, just a bit of sandpaper to clean.
Leesburg, AL
