Laurie's 1970 Fleetwood Brougham Restoration
Started by Cape Cod Fleetwood, December 18, 2017, 03:46:02 AM
Cape Cod Fleetwood
It was chilly, but we got it! I understand the paint and interior codes, the rest???
And I think I'm replacing the battery cables too. Reproduction or....? There's supposed to be a bar that goes over the battery, didn't see anything around the battery to suggest that could/should be there.
Laurie?
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
Cape Cod Fleetwood
OK, I need guidance here.. went to the AC Delco sight and got options on the condensor and points, please tell me which ones I should order?
Condensor - AC Delco# D204 "HD condensor, 68-74"
                    AC Delco# U208 "all, 65-72"
Points -        AC Delco# D106P "all, 68-73"
                    AC Delco# D116 "all, stock perf version, 65-74"
                    AC Delco# D582A "all, high performance version, 65-74"
I don't have a clue what I'm doing here guys, very appreciative of any and all guidance, thanks!
Laurie!
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
cadillacmike68
Quote from: 35-709 on December 30, 2017, 09:41:21 AM
"They have a 'kit' now with the condensor and points together, good thing?"
NOT a good thing.  Some here have found these Delco (Chinese?) combination points and condenser items to be bad out of the box --- including me, on two separate occasions.  I will not/would not use them, period.
Another good reason, for me, to go electronic.
Here is another option worthy of consideration ---
https://www.ebay.com/itm/CADILLAC-472-500-PRO-SERIES-Small-Cap-Black-HEI-Distributor-Coil-Spark-Plug-Wire/191789428878?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
This is an HEI unit but smaller than the GM HEI since they keep the coil separate (included in the kit).  Same size as your stock unit which eliminates the belt clearance problems on your year engine that occur when a GM HEI is added.
I've not had a problem with Uniset points & condenser in the past, but others have. They are easier to put in, and easier to get close to correct when first installing, just match the length of the adjustment screw to the old one and the car will start. Then you can adjust by feel or with a dwell meter. These GM allow you to adjust while the car is running with a 1/8 allen wrench via the slotted door in the cap. The key is to get  points with the hole in the center of one of the contacts. Those are the better made points. Unfortunately ACDelco sells both types. On Rockauto.com, the more expensive one is one I'm referring to. Whatever that part # is, you can look it up on amazon or elsewhere or your local shop.
I'll use either, I have both in my spares boxes, but will prefer the Uniset .
"Cadillac" Mike
cadillacmike68
Laurie,
I think there was a hold-down that used a lever, but I can't remember. That bar in the front is to keep it from falling out.
Black cables for both sides, the thickest you can get, like 2 gauge.
Someone who know more will tell you the paint, top and color codes and the options. The options list is not All the options on the car, just the major ones.
"Cadillac" Mike
cadillacmike68
I thought we were talking about your Fleetwood...   :-X
"Cadillac" Mike
Bobby B
Laurie,
Hi. Knock yourself out.....
                                Bobby
Compliments of Ralph Messina:
http://www.rrrclc.org/wp-content/uploads/2014/05/CLC-Color-Database-2017-03-20.pdf
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Cape Cod Fleetwood
Laurie!
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
Cape Cod Fleetwood
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
Cape Cod Fleetwood
#188
Quote from: cadillacmike68 on December 30, 2017, 04:08:34 PM
Well that's easy...
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
I would go for the D528A.  It looks like its all copper or at least all copper plated plus its got the lubrication wick.
Condenser I don't see the U208 but the D204 looks alright.
Jeff Rosansky CLC #28373
I am not sure where you are, but you may want to keep the cold in mind. I would check to be sure you can/should do it in the cold with a cold metal roof.
Jeff
Jeff Rose
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Cape Cod Fleetwood
Quote from: Jeff Rose                                         CLC #28373 on December 30, 2017, 05:30:38 PM
Jeff
Agree completely Jeff. Hoping to start the body/roof in late March, the temps should be better then.
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
Cape Cod Fleetwood
I can make this easier.. the U208 is no longer being made.
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
Cape Cod Fleetwood
Guys the Ark needs a condensor, note how its missing. Cheapest place to get one? Used is OK, all info greatly appreciated.
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
Bobby B
Three on eBay right now.....
                            Bobby
1971 Datsun 240Z
1979 H-D FLH
Laurie,
You certainly did not ask, but that radiator is going to give you grief at anything above 80 degrees outside, and especially when you have the AC functional. These motors need every "ounce" of radiator they were born with.
Cape Cod Fleetwood
Quote from: "Cadillac Kid"  Greg Surfas 15364 on December 31, 2017, 12:18:09 AM
Laurie,
Its been 'working' fine... but what do you suggest? Laurie?
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
cadillacmike68
#197
I would also go with the D582A points as well. The D116 and D118 uni-set should be OK too, but the D582A and D204 look like the best heavy duty combo.
In general the parts with a D are better than the ones with a C in the front.
I might need to take that back. The C349 cap is better than the D308R cap. Not sure on the two rotors.
"Cadillac" Mike
V63
I would retrofit a ‘modern’ cross flow condenser to it. They are much more efficient...especially with available modern refrigerant.  Cost would be around $110 for a brand new one.
I had a bunch of OEM ones, left over from conversions above. I scrapped them figuring no demand.
Cape Cod Fleetwood
Quote from: V63 on December 31, 2017, 02:24:24 AM
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
