Bumper Fillers for 85 Eldorado
Started by danjarrett1, February 10, 2020, 11:45:43 PM
danjarrett1
Need to replace deteriorated bumper fillers front and back on my 85 Eldorado, prices seem to range from$175 for 11 piece set in fiberglass, up to $600 in ABS. All of the represent that they will need trimming, holes drilled, sanding and fitment otherwise. Has anyone had good results with replacement bumper fillers and can make a recommendation?
1974 Cadillac Eldorado convertible
2007 Cadillac Escalade
1980 Cadillac Seville “Bustleback”
1985 Cadillac Eldorado
MaR
Everything that is currently available is mediocre at best and will take some work to be presentable.
chevy350
Quote from: MaR on February 11, 2020, 10:25:59 AM
I'm in the same boat for my '80 !
Best regards from Sicily,Giuseppe
James Landi
Yes, indeed... have "done" several '80's cadillacs  - two Eldorados and one Fleetwood... the pieces made of fiberglass will certainly last, but it's nearly impossible to use all of the original brackets that were associated with the pliant originals.  After hours of frustration, I simply attached the new ones where they would "mate up" and because they are strong and not pliant, they did stay in place and when I had these cars re-painted, the replacements looked just fine.  (and happily, I never crushed them).   James
danjarrett1
Sounds great, everyone has advised me that I will definitely need to “shape” them into place. Found a place in Miami that makes them to order, full set for $175. Sounds cheap but I’m going to give them a whirl
You dont need all of the original supports because the new parts are more rigid.
My experience with the 85 stuff is that it’s much better than the repro 70’s parts.
